1994 Southwind RV Fuse Panel Diagram & Location Guide
I can't seem to locate the fuse panel diagram anywhere under the dash area. Should I be concerned about testing fuses myself, or is there a safe way to figure out which one controls the power mirrors? I'm worried about causing more damage if I start pulling fuses randomly. Where should these diagrams normally be located, and what's the safest approach if I can't find the original diagram?
The fuse panel diagram for a 1994 Southwind motorhome is typically located on the inside of the fuse panel cover or in the owner's manual. If missing, you can create your own diagram by testing each fuse with the electrical systems.
The Basics
Don't panic — finding the right fuse for your electrical problem in a 1994 Southwind is fixable and usually straightforward once you know where to look. If it's missing or illegible, you can find it in your owner's manual or create your own by identifying suspected fuses first, then testing components individually after fuse verification (ensure ignition is off and key is removed before removing or installing fuses).
Prep Work
- Flashlight or headlamp
- Digital multimeter or test light
- Replacement fuses (various amperages)
- Needle-nose pliers
- Paper and pen for mapping
- Owner's manual (if available)
Fixing the Problem
For your specific power mirror problem:
- Locate the likely fuse: Look for fuses labeled 'PWR ACC,' 'MIRRORS,' or 'ACCESSORIES'
- Visual inspection: Check if the fuse filament is broken or blackened
- Test the fuse: Turn off ignition and remove key, then use a multimeter set to continuity/ohms setting to verify continuity even if it looks good
- Check connections: Ensure the fuse is properly seated and terminals are clean
- Test mirror operation: With a good fuse installed, test mirror functions
Leave These to the Experts
Contact an RV technician or auto electrician if you encounter:
- Multiple blown fuses that keep failing after replacement
- Signs of electrical burning or melted components
- Complex wiring issues behind the dashboard
- Problems with the central electrical distribution system
- Any situation where you're uncomfortable working with electrical systems
Keeping This From Happening Again
- Check ground connections: Poor grounds cause intermittent electrical issues
- Inspect wiring harnesses: Look for cracked, frayed, or corroded wires behind the dash
- Battery voltage: Ensure your chassis battery has adequate voltage (12.6V+ at rest)
- Switch testing: Test the mirror control switch itself for proper operation
AstroAI Digital Multimeter and Analyzer TRMS 6000 Counts Volt Meter Ohmmeter
Reads volts, continuity, and resistance — the #1 tool for tracing 12V faults. View on Amazon →
Flashlights High Lumens Rechargeable, 100,000LM LED Super Bright Flash Light
Bright rechargeable light for bays and undercarriage. View on Amazon →
WORKPRO Mini Pliers Set, 3-Piece Small Pliers Tool Kit Includes 4” Diagonal
Reaches and grips in tight wiring and plumbing bays. View on Amazon →
ZIPCCI 80 Pcs Standard Car Fuse, Fuses Assortment
Standard + mini blade fuses in every amperage you are likely to blow. View on Amazon →
- RV Backup Camera Not Working? Complete Troubleshooting Guide
- RV Chassis Battery Draining & Dead Outlets - Troubleshooting
- RV 12V Lights Dimming: Complete Troubleshooting Guide
- RV Electrical Problems: 12V & 120V Troubleshooting Guide
- RV Electric Steps Won't Retract - Sensor Location & Fix
- ECM Low Battery Warning RV: Complete Diagnosis & Fix Guide
- RV Shore Power Not Working: Complete Troubleshooting Guide
- Protect Your RV Alternator When Charging Lithium
- No 12 Volt Power in RV: Complete Troubleshooting Guide
- RV DC Electrical System: Expert Guide to 12 Volt Systems
