2022 Newmar Bay Star 3609 Steering Play & Tire Wear Issues
However, the owner mentioned there's still noticeable steering wheel play, and when I looked at the tires, the outer edge of the right front is significantly worn while the left front looks perfectly even. For such low mileage, this seems concerning to me. The owner says he gets annual alignments done professionally, so if it's not alignment causing this, what else could it be?
I'm worried there might be something seriously wrong with the chassis or steering components that could be dangerous or expensive to fix. Am I being overly cautious, or are these red flags I should walk away from? I really don't want to buy someone else's problem, especially when it comes to steering safety.
Your concerns about the 2022 Newmar Bay Star 3609 are valid - steering play combined with uneven right front tire wear at only 11k miles suggests issues beyond normal F-53 characteristics, even with Liquid Springs and Safe T Plus installed.
Cut to the Chase
Your concerns about this 2022 Newmar Bay Star 3609 are absolutely justified. The combination of noticeable steering play and uneven tire wear on the right front at only 11,000 miles, despite having Liquid Springs and Safe T Plus installed, strongly suggests an underlying mechanical issue beyond simple alignment. The F-53 chassis, while robust, is known for specific wear patterns that can develop even with low mileage, particularly in the steering box, pitman arm, and tie rod ends. The fact that the right front tire shows significant outer edge wear while the left remains even indicates either a bent component, worn steering linkage, or improper toe settings that haven't been properly diagnosed.
Given that Josam has a solid reputation and performs annual alignments, the persistent tire wear pattern suggests they may be compensating for a worn component rather than addressing the root cause. The steering box adjustment screw on the F-53 can mask worn internals temporarily, but if the owner has already attempted this adjustment or if it's been done repeatedly, you could be looking at internal steering box wear that requires replacement. At 11,000 miles, this would be unusual but not unheard of, especially if the coach experienced any significant impacts or was driven extensively on rough roads during its early miles.
The Why Behind It
The Ford F-53 chassis uses a recirculating ball steering system that's inherently more prone to developing play than modern rack and pinion systems. The steering box contains internal components including the worm gear, ball nut, and sector shaft that can wear prematurely due to several factors. Heavy motorhomes like the Bay Star 3609, which weighs approximately 22,000-24,000 pounds loaded, put considerable stress on these components. Even with the Liquid Springs air suspension upgrade providing better weight distribution and the Safe T Plus stabilizer reducing road shock transmission, the fundamental steering components still experience significant loads.
The uneven tire wear pattern you observed is particularly telling. When the right front tire shows outer edge wear while the left remains even, this typically indicates one of several conditions: excessive toe-out on the right side, a bent tie rod or drag link, worn tie rod ends specifically on the right side, or a problem with the steering box itself creating unequal steering geometry side-to-side. The outer edge wear pattern suggests the tire is scrubbing as it rolls, which happens when the wheel isn't tracking straight ahead during normal driving.
Liquid Springs and Safe T Plus are excellent upgrades that should indeed provide tighter steering feel and better handling. The fact that you're still experiencing significant play despite these modifications indicates the problem lies in the basic steering linkage components. The Safe T Plus works by dampening steering oscillations and reducing driver fatigue, while Liquid Springs improve ride quality and reduce body roll, but neither system can compensate for worn steering box internals or loose tie rod connections.
Another consideration is the alignment shop's approach to the problem. Some shops will set alignment within specification limits to compensate for worn components rather than recommending component replacement. This can result in settings that appear correct on paper but don't address the underlying mechanical wear. If the steering box has excessive internal play, even perfect alignment settings won't prevent uneven tire wear because the wheels won't maintain their set positions during driving.
Prep Work
Before making any purchase decision or beginning diagnostic work, you'll need to perform a comprehensive inspection of the steering system components. Start by gathering the necessary tools: a dial indicator with magnetic base, a spring scale capable of measuring 15-20 pounds of pull, jack stands rated for the coach's front axle weight, a pry bar, and a good flashlight or LED work light. You'll also want to have the specific torque specifications for the F-53 chassis, which are available in the Ford chassis manual.
Document the current tire wear patterns with photographs before any inspection work. Measure the tread depth at multiple points across each front tire using a tread depth gauge. Pay particular attention to the differences between inner, center, and outer tread blocks. Normal tread depth variation should be minimal across the tire width, though some variation is expected due to manufacturing tolerances and normal wear patterns.
Obtain the maintenance records for the coach, particularly any work done on the steering system, alignment reports, and tire rotation schedules. This information will help establish whether the problem is progressive wear or a recent development. If the owner has attempted to adjust the steering box, try to determine when this was done and whether the problem improved temporarily before returning.
Check the current alignment specifications against Ford's recommended settings for the F-53 chassis. Check Ford's specifications for your specific F-53 model year and GVWR class, as alignment specifications vary significantly between different F-53 variants and years. However, these specifications can be modified slightly depending on the specific tire and wheel combination and the coach's weight distribution.
Step by Step
Begin your diagnostic process with the coach parked on level ground and the engine off. First, check for steering play by turning the steering wheel slowly left and right while watching the front wheels. There should be minimal steering wheel rotation before the wheels begin to move - check manufacturer specifications for acceptable free play limits on your specific F-53 model year and weight class. If you observe more play than this, the problem could be in the steering box, steering shaft connections, or linkage components.
With the coach still on the ground, have someone turn the steering wheel slowly while you observe the steering linkage components from underneath. Watch specifically for excessive movement in the tie rod ends, drag link connections, and pitman arm attachment. Any visible play in these joints indicates worn components that need replacement. Pay particular attention to the tie rod ends, as these are common wear points on the F-53 chassis and can cause the exact tire wear pattern you described.
Next, engage the parking brake and chock the rear wheels, then raise the front of the coach using appropriate jack stands placed on the frame rails, not on axle components. With the front wheels off the ground, grasp each wheel at the 3 and 9 o'clock positions and attempt to rock it horizontally. Any movement indicates worn tie rod ends or other steering linkage wear. Then grasp the wheel at 12 and 6 o'clock positions and check for vertical movement, which could indicate worn wheel bearings or suspension components.
Perform a more detailed inspection of the steering box itself. Locate the adjustment screw on top of the steering box and check whether it appears to have been recently adjusted. The lock nut should be tight, and there should be witness marks or paint indicating the original factory position. If these appear disturbed, previous adjustment attempts may have been made. Remove the pitman arm using a proper puller and inspect the steering box output shaft for wear or damage.
Check the drag link and tie rod assemblies for straightness and proper length. A bent drag link can cause steering pull and uneven tire wear even if alignment angles are set correctly. Measure the length of both tie rods to ensure they're equal - unequal lengths can indicate previous accident damage or improper alignment procedures. Inspect all steering components for wear, damage, or looseness, paying particular attention to the areas where uneven tire wear patterns suggest problems may exist.nt boots and seals for leaks, which indicate internal component wear.
If you decide to attempt a steering box adjustment, this should only be done if all other steering components are confirmed to be in good condition. Consult a qualified technician for steering box adjustment procedures specific to your F-53 chassis year. Components are confirmed to be in good condition. The proper procedure involves disconnecting the pitman arm, backing off the adjustment screw completely, then slowly tightening while measuring the torque required to turn the steering shaft. The specification calls for 4-10 inch-pounds of torque to rotate the shaft through center position. However, if the box has significant internal wear, no amount of adjustment will provide lasting improvement.
Beyond Your Garage
Given the complexity of this steering issue and the potential safety implications, professional diagnosis and repair may be your best option, especially if you're not familiar with F-53 chassis characteristics. However, not all shops are equipped to handle large motorhome chassis work. Look for shops that specialize in commercial vehicles or have specific experience with Ford F-53 and F-59 chassis systems. These shops will have the proper equipment to handle the weight and size of the coach safely.
When selecting a repair facility, inquire about their alignment equipment capabilities. The coach will need to be aligned on a heavy-duty alignment rack capable of handling the weight and wheelbase of the Bay Star 3609. Many passenger car alignment shops cannot accommodate vehicles of this size and weight, and attempting alignment on inadequate equipment can lead to inaccurate results or safety hazards.
Cost considerations for this repair can vary significantly depending on which components need replacement. A complete steering box replacement on an F-53 chassis typically runs $800-1200 (rough ballpark — actual cost varies by region, brand, and model year and changes over time, so get current quotes) for the part plus 4-6 hours labor. Tie rod ends range from $150-250 each, and a complete drag link assembly can cost $300-500. If the pitman arm needs replacement, add another $200-300. Professional alignment service for a large motorhome typically costs $150-250, but may need to be performed multiple times if components are replaced in stages.
Consider the long-term implications of purchasing a coach with these issues. While the problems are definitely repairable, the fact that they've developed at such low mileage raises questions about the coach's history. The seller should be willing to address these issues or negotiate the repair costs into the purchase price. Factor in that you may also need to replace the front tires due to the uneven wear, which could add another $600-800 for quality tires appropriate for the coach's weight rating.
Before finalizing any purchase, insist on a professional inspection by a qualified RV service center or commercial vehicle shop. This inspection should include a complete steering system evaluation, alignment check, and assessment of all chassis components. The cost of this inspection, typically $200-400, is minimal compared to the potential repair costs you could face after purchase. If the seller is reluctant to allow this inspection or address the identified issues, consider walking away from the deal regardless of other attractive features the coach may have.
